Hi.
Im searching for a cadfile to compare my measurements with. Anyone have the boltpattern in a file, or on paper? showing the B230 boltpattern, and likewise the boltpattern for the mercedes 722.6 gearbox(OM606 or similar will do).
Im trying to pair up the 722.6 gearbox to a volvo redblock. Anyone that has done something similar in here?
bellhousing bolt pattern, Volvo B234 + MB 722.6
Re: bellhousing bolt pattern, Volvo B234 + MB 722.6
Make sure you get an AMG version of 722.6 above 2004.
It will take almost anything you throw at it.
With bluetop solenoids they are upgraded to same spec as Mclaren SLR.
With aftermarket control they can be shifting HARD!!!!
Mine with std(but reprogrammed) tcu unit, it chirps the tires running in manual mode.
I cannot help you more than many mercedes has the samt boltpattern, so you might be able to widen your search.
Rgds
edit: blue vs brown, hot to spot, unmissable
Rgds
