Planning to use megasquirt on my car. For the ignition I had planned a MSD 6-BTM. I've looked for a programmeble ignition but I just find a unit from MSD. Are there any other reliable ignitions on the market?
//Koen
injection - ignition
Moderator: backeliten
Have you looked into MegaSquirt'n'Spark ? (I will run it on my B20)
Here you can see the alternatives you have available with MegaSquirt:
http://home.earthlink.net/~jcgebhart/megaignite.html
MS'n'S can be used with a simple and cheap MSD 6A, or any ignition amplifier similar to it. Ignition advance is delayed by the MS'n'S.
/Mattias
/Mattias
