Fick lite info om ett nytt insprutningssystem verkar kosta runt 4000:- i byggsats men med bredbandslambdasond. Kolla spec här under:
MCU: AtMega128
Drivers
8 high current ignition drivers.
8 injection drivers supporting peak-hold injectors.
2 High current misc outputs.
1 Idle stepper driver. (Can be used as four induvidual 1A push-pull drivers)
4 350mA protected open collector drivers with pullup.
1 350mA protected open collector driver for fuel pump relay
1 350mA protected open collector driver for small idle solenoids
2 350mA protected open collector drivers driving LED's. Available for other applications if connected on board.
Communication
2 RS232 ports
1 1wire communications port.(Replaces one RS232)
1 onboard LCD support
1 Onboard PS/2 keyboard support
Feature connector for CAN bus and MMC (multimediacard) addon boards.
Fast serial boot loader for firmware updates.
Sensor inputs
2 Variable reluctance/Hall sensor inputs
2 knock sensor inputs with advanced DSP based signal conditioning.
Onboard Manifold Absolute Pressure sensor (MAP)
Colant temperature sensor (CLT)
Intake Air Temperature sensor (IAT)
Throttle position sensor (TPS)
2 misc inputs for resistive sensors, like exhaust back pressure and fuel pressure.
2 LSU4 WBo2 controllers (bredbandslambda)
2 TypeK? EGT sensor amplifiers
several internal sensor inputs for custom applications.
Enclusure and connectors:
Automotive grade AMP Econoseal III connectors
Extruded Alubos enclosure with CNC machined endplates.
Genboard v3 Target Features
Support for most common trigger arrangements.
1-8cylinder full sequential injection with Coil on plug/coil near plug, waste spark, 1-2 distributors.
10-16cylinder semi sequential with wastespark/ 1-2 distributors.
2ch knock sensing.
Wide open throttle closed loop Lambda control (WOT closed loop)
Selflearning VE table.
2ch Exhaust gas temperature.
Idle control
Om det här fungerar bra skulle jag tro att det blir ngt prisvärt
finns mer att läsa på TPC-forumet (avancerat)
samt http://www.vems-group.org/
MVH Jonas T
billigt och bra sprut på väg ut på markanaden?
Moderator: backeliten
Ja det verkar som ett bra system!
Blir spännande att höra hur det funkar snart då
Köpte du ditt system direkt från:
http://shop.x-dsl.hu/catalog/index.php? ... 8027c35265
/Marcus
/Marcus
ja prisvät så som gammla versionen av megasquirt, ser mycket intressant!
- Fredde Holmgren
- Impellerhead
Jag har hjälpt emil lite med testningen av sprutet och det verkar lovande!
Fler Sponsorer sökes!
halvkomplett köper man det.. Vill man inte löda ytmonterat och montera i bil själv kommer jag kunna hjälpa till med detta för lämplig ersättning
Vi kommer även bygga adapter-härvor till försäljning passande volvos turbomodeller till att börja med.. (motronic, LH-jetronic...)
Bilen med insprutningen kommer fungera till en dag på strippen piteå..
hur likt är det megasquirt? fördelar nackdelar? följer det verkligen med en äkta bredbandslambda? är intresserad av megasquirt men vet inte vad man ska ha för tändning, kanske megajolt eller va de heter, finns det nått alternativ till detta eller ska man köra MSD?
det jag undrar eg. är om det är bättre att köpa detta nya sprutet än ett megasquirt.. för de känns ändå lite mer beprövat... men ska man köpa till en bredbandslambda blir de ju hyffsat dyrt... ska inte köpa innan strippen piteå så får väll vänta & se på resultatet.....
