Aktuellt datum och tid: tis apr 24, 2018 9:56 am
Ny tråd Svara på tråd  [ 3 inlägg ]
 Inläggsrubrik: Standalone
InläggPostat: sön feb 26, 2017 1:58 pm
Hi guys.I am new in this topic but i am interested in converting my car to standalone.It is Fiat Coupe 20 VT with GTX3076,FMIC,630cc Siemens injectors,etc which is currently running on stock ECU.I would like to have some more options like antilag,launch control,boost control.What would you suggest as best option between VEMS,Ecumaster or Maxxecu?I am looking for something that is not to complicated to install since i intend to do it myself,and use someone experienced to map the car.Also it would be good to use original wiring loom because everything is working without problems.Any suggestions are welcome.Thanks
 Inläggsrubrik: Re: Standalone
InläggPostat: sön feb 26, 2017 10:54 pm
I would use what your tuner is comfortable with, you should also add Haltech and Link ECUs to your list.
Mattias Sandgren
InläggPostat: mån feb 27, 2017 6:52 am
I am not even sure who is going to map the car. Need to find someone in Göteborg area or close.
Användare som besöker denna kategori: Inga registrerade användare och 6 gäster
