Camshaft sensor
Moderator: backeliten
bojke
Camshaft sensor
Inlägg av bojke »
I need a help again.Need to wire camshaft sensor to maxxecu.My stock sensor has 3 pins.
1. +5v
2. sensor output
3. shield
I have 2 wires coming from maxxecu ecu,which are white and brown. How do i conect those 2 wires to the sensor?
Thanks in forward.
Regards
__Mackee__
Re: Camshaft sensor
Inlägg av __Mackee__ »
1. +5v. you need to solder a wire from ex tps or the 5v out form maxxecu
2. sensor output. White
Brown = sensor ground.
The shield ground is around the cable.
What sensor are you using ?
bojke
Re: Camshaft sensor
Inlägg av bojke »
Hi.
I am useing original wiring loom from a car to which i am connecting maxxecu wiring.
the car has bosch sensor part number 0.232.101.026.
And its connected like this to standard ecu:
-pin 3 is connected as shield to engine block
-pin 2 is signal to ecu
-pin 1 is plus 5v
Now i have two wires coming from maxxecu for cam sensor.I already connected pin 1 of the sensor to maxxecu +5v.But i already have ground on pin 3 connected in original loom.I understand that probably white wire should go on pin 2 of sensor which is signal.What should i do then with brown wire which is coming together with white?
