Saabel Garage; GMC Typhoon #FinnTyphoon
keme
Re: Saabel Garage; Saabel Rekord engine updates
Inlägg av keme »
Wrote to Santa. Hope he delivers :D
Hasse Bus
Inlägg av Hasse Bus »
Ha ha ha, klockrent. :thumbright:
Hans-Åke Rahm.
keme
Inlägg av keme »
Santa stood me up and brought just socks. :D
Target for next summer is to go faster than current record 11.8/192.
keme
Inlägg av keme »
Got the wastegate tack welded, but I have to adjust the angle a bit. All in all it it fits quite nicely.
keme
Inlägg av keme »
Exhaust manifold ready for welder :)
keme
Inlägg av keme »
Over size pistons and 147mm H-beam rods arrived to the engine.
keme
Inlägg av keme »
Got the B206 block back from the machinist. Now it is bored to 1mm oversize ie. 91mm, the head surface is skimmed and oil squirters have been installed.
keme
Inlägg av keme »
Custom flywheel for Audi -754 clutch. Now it fits properly between SAAB engine and BMW gearbox :)
keme
Re: Saabel Garage; Saabel Rekord new exhaust manifold ready
Inlägg av keme »
Got the manifold back from the welder. It looks so nice :)
keme
Inlägg av keme »
Got the skimmed head and slightly machined pistons back from the machinist. Now I should have all the bits an pieces to get the engine assembled.
keme
Inlägg av keme »
Mated a timing plate with a Saab aux wheel. Now I should be able to get the cams timed properly.
keme
Re: Saabel Garage; Are Saab engines unsuitable for RWD setup
Inlägg av keme »
Opened the engine I built at the end of last summer. I drove it in dyno and then five quarter mile passes. Today I opened it and 2nd con rod bearing looked like this
That is not that bad, but 2 & 3 Main bearings looked like this
Are there some serious oil feed problems with stock NG900 oil pan on RWD use or what the shit?
Also I checked the cam timing.
Exhaust cam was in the right ball park, but the intake cam was waaaaaaay retarded
I did measure the timing last summer, but how on earth I managed to measure that so wrong.
Manfred
Inlägg av Manfred »
Any pictures of the inside the oil pan?
quattro
Inlägg av quattro »
Hi, nice car. :thumbright:
A few comments:
A retarded inlet cam means that inlet valve closes later. This lowers low to mid-range torque, which actually might have been a good thing as you were running original con rods.
It's not hp that kills con rods, it's torque (bending) or too high revs (rod cracking or bolts snapping). Or bad oil supply (bearing seizure).
It seems to me that you've probably have had both torque induced bending and bad oil supply. I would change to after market H-profile con rods, and make sure that the oil level in the pan cannot drop below the pick up, no matter the g-forces working on the car. Could you log the oil pressure through-out a drag race run in order to see exactly what happens? Or make the ECU cut ignition if oil pressure falls below a certain level?
Gabbe_96
Inlägg av Gabbe_96 »
An easy fix to the oilproblem would be installing a oilacumulator, because it seems that oil can go backwards/frontwards without a problem?
M30 turbo
