Aktuellt datum och tid: lör feb 23, 2019 8:36 am
Ny tråd Svara på tråd  [ 544 inlägg ]  Gå till sida Föregående  1 ... 32, 33, 34, 35, 36, 37  Nästa
InläggPostat: mån apr 09, 2018 4:32 pm
Manfred skrev:
Any pictures of the inside the oil pan?
Got the oil pan a bit modified
Now the oil should not escape from the pick up as easily as in stock setup.
Saabel Garage
InläggPostat: mån apr 23, 2018 12:29 pm
Slow progress continues; started the engine build.
Saabel Garage
InläggPostat: fre apr 27, 2018 10:12 am
Nice!! =)
Whats cams are you driving with?
Mvh Roberth
InläggPostat: tis maj 01, 2018 9:18 am
Mvh Roberth
I´ll put 268/9.6 Enem cam on intake and 276/10.4 Enem cam on the exhaust at this next engine.
Saabel Garage
InläggPostat: lör maj 05, 2018 11:28 am
Bottom end is ready!
Saabel Garage
InläggPostat: sön maj 06, 2018 8:20 pm
All set for cam timing.
Saabel Garage
InläggPostat: lör maj 19, 2018 9:41 am
Dropped the engine back in the enginebay, so that I can do the gearbox rearmount and check the clearances. Began to do new downpipe and exhauspipe.
Saabel Garage
InläggPostat: sön maj 27, 2018 9:33 am
keme skrev:
Mvh Roberth
Okok i see, why do you gonna go with that spec, why not de 276 on intake and 268 on exhaust?
Mvh Roberth
InläggPostat: tis maj 29, 2018 8:14 pm
Mvh Roberth
I was told that this would work best at my engine setup. 2.3 bottom end, ported head, 38x1.5mm primaries on exhaust manifold and after the collectors 41.5x1.5mm up to the turbo. I am looking to get 500whp with good power band.
got the downpipe and firewall modifications done.
Bild Bild Bild
Firewall at the begining
and after :D
Not the prettiest outcome, but it is functional. With a little paint it will propably look semi-decent.
Saabel Garage
InläggPostat: tor maj 31, 2018 7:14 pm
Got 26x9.5 Hoosiers mounted on wheels. They look pretty beefy and I really hope they will fit...
Saabel Garage
InläggPostat: tis jun 05, 2018 2:20 pm
26x9,5 fits on my rekord, but I got different wheels and a volvo rearend. But there is no problem clearing the wheelwells!
InläggPostat: sön jun 10, 2018 10:07 am
Yeah, the fitment was quite close because my wheels should be more inwards.
Oil for my GS6-37DZ gearbox and 8mm sinter plate. Ortered these from Lensu power shop and the delivery was Super fast.
Put a JIC12 fitting into the oilpan because there is no place for oil return in Saab B206 cylinder block. Hope this works.
Lately I have been posting more stuff to Instagram, but I still try to keep also this topic alive :)
https://www.instagram.com/saabelgarage/
Saabel Garage
InläggPostat: tor jun 14, 2018 12:09 pm
Painted the exhaust manifold with VHT flame proof
Hionta ja koneistus HS OY machined the turbine housing for 3.5" V-band fitting.
Double checked the cam timing and now it should be 108/108.
Saabel Garage
InläggPostat: tor jun 14, 2018 2:43 pm
that exhaust header looks sweet!
nice work, man.
InläggPostat: sön jul 08, 2018 8:54 pm
nice work, man.
Had to "machine" a bit of the gearbox input shaft. This gearbox has been made for Opel flywheel and clutch, so the input shaft was a bit too long to my setup.
I had to adjust also the throw out bearing, because my flywheel and clutch setup is taller than Opel parts. Minor adjustments with angle grinder :)
Engine and gearbox was already in the engine bay and engine was running for few seconds, but I had to remove it once again. I am looking to get it properly running next week. Then I can book dyno time and get it tuned.
Saabel Garage
Användare som besöker denna kategori: Inga registrerade användare och 17 gäster
