Aktuellt datum och tid: lör maj 25, 2019 6:29 pm
Ny tråd Svara på tråd  [ 558 inlägg ]  Gå till sida Föregående  1 ... 33, 34, 35, 36, 37, 38  Nästa
InläggPostat: tis jul 10, 2018 4:12 pm
https://www.instagram.com/p/BlDYC5XA75S ... abelgarage
Got the new engine finally started today!
Saabel Garage
InläggPostat: ons sep 19, 2018 2:05 pm
Pff... Haven´t got anything done, except I sold the old ECU with DASH2 and ordered a Maxxecu Race ECU.
Continuing about things I haven´t got anything done; the Caravan Rekord has been untouched for ~two years. Maybe I should continue that project also some day.
Saabel Garage
 Inläggsrubrik: Re: Saabel Garage; BMWomega
InläggPostat: fre okt 05, 2018 1:50 pm
So the winter is coming and I had to buy a winter beater. Spotted add of an Opel Omega with BMW M52B28tu engine and that solved the winter car problem at once. Of course I had to test how it drifts. Put 10pcs tires on a trailer and went to Lapua last Saturday.
It kind a drifted. Under powered and over weight pig, but had a lot of fun :D
The engine has E36 M3 exhaust manifold, some sort of chip in ECU and M54B30 intake manifold. Therefore I had to go to dyno and check out what kind of power it makes.
138kW/233Nm at the wheel. Not an actual race car, but maybe few kilowatts more than stock? :D
There is also a video of the dyno; https://www.instagram.com/p/BoWR1T-gv6u ... abelgarage
Saabel Garage
InläggPostat: lör okt 06, 2018 12:12 pm
BopWelM??? :hihi:
\\ fugazi \\ Magnus \\
Starion Turbo -83
Outlander -05
Lancer Kombi -96
GARAGET
InläggPostat: mån okt 08, 2018 12:35 pm
fugazi skrev:
BopWelM??? :hihi:
:D That sounds a bit difficult :D
Saabel Garage
InläggPostat: tis okt 16, 2018 7:47 pm
Almost got the Saabel Rekord started with new Maxxecu. Just the RPM signal was missing. If someone knows pin order for Saab crank sensor 90451441 it would be very much appriciated
Saabel Garage
InläggPostat: tor okt 18, 2018 12:44 pm
https://www.instagram.com/p/BpCvaxugA87 ... abelgarage
Got it running with Maxxecu yesterday! :)
Saabel Garage
InläggPostat: tor okt 18, 2018 9:15 pm
Congratulations, nicley done :thumbright:
/David
Camaro Turbo.
Kadett C Turbo.
viewtopic.php?f=21&t=86085
InläggPostat: fre okt 19, 2018 4:03 am
Nice build,
InläggPostat: sön nov 18, 2018 3:04 pm
#ifmycarwasashoechallenge
https://www.instagram.com/p/BqUnr5XA4Kl/
It just had to be done just because it was so stupid idea :D
Saabel Garage
InläggPostat: tor dec 06, 2018 7:49 pm
Drove the Rekord today! It was just around the garage but it counts.
Had to take also some video evidence :D https://www.instagram.com/p/BrC_J2cg8yL/
Saabel Garage
InläggPostat: mån dec 17, 2018 9:31 pm
Made temporary screamer pipe for dyno. Hope it actually is just temporary solution :D
Saabel Garage
InläggPostat: fre dec 21, 2018 7:44 am
All set in the engine bay. Saturday is the dyno day.
Saabel Garage
InläggPostat: sön dec 23, 2018 12:07 am
Well done! :thumbright:
I hope the visit too the Dyno was successful and that you made good power!
/David
Camaro Turbo.
Kadett C Turbo.
InläggPostat: sön dec 23, 2018 9:37 pm
Well... The dyno was yesterday and the result was 85kW at the wheel. Gearbox leaked oil to the clutch and that was the end of the session. Engine felt quite goood and next dyno time will be before summer.
Checked all the bolts were tight before dyno
Up on trailer and of to the dyno
On the dyno. Didn´t get proper dyno pulls before the gearbox spewed oil to the clutch.
I had to leave Rekord out in the cold because starter died on the trailer. There is a slight up hil in to the garege, so I couldn´t push it there :(
Put a beanie on turbo, because it looked to be so cold :D Den turbomössa är inte från Biltema :D
Saabel Garage
Användare som besöker denna kategori: Inga registrerade användare och 8 gäster
