Saabel Garage; GMC Typhoon #FinnTyphoon
keme
Re: Saabel Garage; Saabel Rekord
Inlägg av keme »
Dennis M skrev:Lower is "immer besser" as the commercial says!
Indeed!
Modified the downpipe and checked that how much the fire wall needs modification due engine has moved a bit back. Luckily it needs only very little cutting. Looking goooood.
keme
Inlägg av keme »
Painted the engine bay and now it looks slightly less hidious. Next weeks plan is to put engine back in and fire it up!
MickeK
Inlägg av MickeK »
Nice, looks good
MVH Micke
Med mål på 6,50 på 201m
PB 6,52s/182km
keme
Inlägg av keme »
Getting closer. Just noticed that I have to re-do the passenger side engine mount. With NG900 alternator the old engine mount doesn´t fit. Next intresting situation will be with the NG900 waterpump. Looks like that it will come very close to roll cage. Hopefully there is enough space for coolant hose.
keme
Inlägg av keme »
Improved the gearbox breathing with R1/4 thread and a 10mm fast connector.
With new engine mounts and gearbox bracket the engine fits properly into the engine bay. Luckily that few centimeters movement didn´t cause too big changes. Previously I was thinking that I would start it up this week, but maybe next week. Few bits and pieces missing, but loooking gooooooood!
Dennis M
Inlägg av Dennis M »
Keep up the good work!
keme
Inlägg av keme »
Got the downpipe and pipe from turbo to cooler done. Hoping to get engine running this weekend.
keme
Inlägg av keme »
Original power steering pump didn´t fit next to turbo so it got removed. Took the grooving from 9000 waterpump and welded it on top of the NG900 pump and put a 1755mm serpentine belt to run waterpump and alternator.
keme
Inlägg av keme »
https://youtu.be/bbD3jI1e8nY and it idles! YEAH!
Dennis M
:beerchug:
W108
Inlägg av W108 »
Thats nice !!!
keme
Inlägg av keme »
Put a Mercedes power steering pump into the engine bay. Problem is that I don´t have any wiring diagram for that and I would like to get that adjustable.
All tips are much appreciated!
David Herbertsson
Inlägg av David Herbertsson »
Sounds and looks good! I´m looking forward to some test-driving videos!
/David
Camaro Turbo.
Kadett C Turbo.
keme
Inlägg av keme »
David Herbertsson skrev:Sounds and looks good! I´m looking forward to some test-driving videos!
Thanks! So am I! :D
Had to cut bonnet a bit more because compressor housing had to be rotated. Also noticed that engine has moved a bit towards the driver side with new engine mounts.
dahla
Inlägg av dahla »
Mount a transparent scoop too :)
Patrik Dahlström
