Fundering squish zone och CR B234f low budget
Diskussioner för erfaret folk
Hempp2_
Inlägg av Hempp2_ »
Hello
You can answer with swenska, I can understand it, but the writing takes a eternity...
I sold my old 8 valve turbo engine as a packet, so my 244 needs new engine. I have b234 head and misc. I have in my mind getting b230FB bottom with oilsquirters. I'll swap my spare H-profiles and bore the oil return to block.
I have to mill the valve reliefs to pistons, but I allso thought that I could mill the head of the piston flat to get lower the CR...
Will this ruin the squish zone effect and does it matter on 16v valve setups?
I calculated the differences in CR
b230f original as a test
bore 96mm
stroke 80mm
hq 99mm/1mm (id/thickness)
Combustion Chamber Volume 53.7cc
Enter Piston Dome Volume In CC -7.23cc (64,7x2.2mm)
Enter Piston Deck Clearance -0.4mm
CR=> 9.8
B234f head + b230fb bottom (didn't calcultated the size of valve reliefs)
bore 96mm
stroke 80mm
Combustion Chamber Volume 48.5cc
CR=> 10.5
B234f head + b230fb pistons milled flat (didn't calcultated the size of valve reliefs)
bore 96mm
stroke 80mm
Enter Piston Dome Volume In CC -15.924cc (96x2.2mm)
Enter Piston Deck Clearance -0.4mm (The real clearence of the piston to head is 1mm-0.4mm+2.2mm=2.8mm)
CR=> 9.35
My choise would be the last one, if the milling the wount ruin the charagesteristics of the swirl on the combustionchamber
I drive with e85, but somehow I prefer little lower cr and higher boost pressures. Have tried to map 1:10 cr engines, but there is allways a little fear to dial the boost up and give larger spark advances to gain torguen and power...
Pacman
Re: Fundering squish zone och CR B234f low budget
Inlägg av Pacman »
Min första tanke är B230FK/FT kolvar med frästa ventilurtag. Är det svårt att få tag i sådana där du bor?
//Pacman
(Patrik Ståhl)
Hempp2_
Inlägg av Hempp2_ »
I found FT pistons, I planned using the FB pistons because I did't have any turbo pistons strored for this project...
