Aktuellt datum och tid: tor sep 20, 2018 12:25 pm
Ny tråd Svara på tråd  [ 527 inlägg ]  Gå till sida Föregående  1 ... 28, 29, 30, 31, 32, 33, 34 ... 36  Nästa
InläggPostat: sön jan 15, 2017 1:26 pm
Realy nice car you cot here! Looks nice with the new brakes! :D
Tack till:
Bil Bengtsson i Simrishamn
do88.se
KL Racing
InläggPostat: tor jan 19, 2017 5:57 pm
Thanks! Relating to the brakes.
I got the brake pads. Assembled the front brake pads without any problems, but then with the rear pads I ran into a problem. I had to stop the assembly because I almost died in laughter.
I didn´t remember that Saab 9000 brake pads are this small! Come on! My daily driver key chain is bigger and the sticker in the packet are bigger than the performance brake pads :D These look like they are ment for bicycle. Well, they should work ok but the size is just rediculous :)
Saabel Garage
InläggPostat: sön jan 22, 2017 3:08 pm
Relocated the oil cooler from the wheel well back in front of the car. Have to cut a few holes in bumper to increase the air flow to oil cooler and ofcourse for the racing look :D
Saabel Garage
InläggPostat: tis feb 21, 2017 4:07 pm
Cut the passenger floor for the v-band connector and exhaust flex piece. There was space for 3" exhaust pipe, but 3.5" exhaust flex and v-band just could not fit in that space. Also now I got more space between exhaust pipe and gearbox mounting rubber. Win win.
Saabel Garage
InläggPostat: tis feb 21, 2017 5:52 pm
Super cool build! Keep up the good work!
Gabriel Mattila
InläggPostat: mån apr 03, 2017 9:56 am
Actually I haven´t got anything done. Visited briefly in garage and made a To Do list of missing parts and works. 12.5. there is a track day where I am going to participate, so it would be good to get at least some of those things done before that. Few things with chassis, engine, brakes, steering and electrics should be done prior driving. Should be possible, but we´ll see...
Saabel Garage
InläggPostat: mån apr 10, 2017 6:50 am
Steering rack sealings seem to be fucked.
Saabel Garage
InläggPostat: sön maj 07, 2017 5:09 pm
Half way on the steering rack sealing change.
Saabel Garage
InläggPostat: sön maj 07, 2017 6:13 pm
That was some tiny brakepads! :P
Tack till:
do88.se
KL Racing
InläggPostat: ons maj 10, 2017 8:26 pm
Indeed :D
Got the steering rack done.
Well didn´t get those done, but there is still quite much time left before summer begins :D
Saabel Garage
InläggPostat: fre maj 19, 2017 3:04 pm
Got the fuel back from welder who welded AN8 fittings at the end of the Cosworth Sierra fuel rail. It has same injector spacing as Saab engine, but inner diameter of the rail is waaaay bigger. Saab fuel rail has ~5mm fittings at the end. Also picked up an Aeromotive fuel pressure regulator. So the fuel system is slowly getting together.
Saabel Garage
InläggPostat: mån maj 29, 2017 6:07 am
Fuel catch can with Walbro 450LPH pumps is ready. This fuel pump setup is "a bit" overkill for me, but one might be not enough and these are so cheap that there is no reason to buy something else. Also they are E85 suitable. Got the steering rack assembled and engine removed. There are few things that have to be done in engine bay and without engine it is much easier to work there.
Saabel Garage
InläggPostat: sön jun 04, 2017 4:27 pm
Dropped the engine back in.
Saabel Garage
InläggPostat: fre jun 09, 2017 7:35 pm
Got the oil cooler hoses, steering pump hoses and turbo oil lines done and test fitted them. Fuel rail, fuel pressure requlator and fuel lines are yet missing. Then it would be start up time!
Saabel Garage
InläggPostat: fre jun 16, 2017 7:24 am
Got the Cosworth Sierra fuel rail with AN8 fittings fitted into Rekord intake manifold. The plan is to get this thing started next week.
Saabel Garage
Användare som besöker denna kategori: diskaren och 8 gäster
