turbine flange type
- Lite mer laddtryck
turbine flange type
I was wondering how I attach the Down pipe to this type of turbine housing. My friend gave it to me and said it was a vband style. Which it obviously is not. Here are some pictures.
Thanks,
Jess
Thanks,
Jess
Jess, what manufacturer is that?
And what vehicle use the original turbo?
it is a garret p trim t4 spit tang housing. I do not know what type of vehicle it came of off. I can ask my friend later but I doubt he'll know as thye just had this laying around.
Edit, I think I remember them using a larger looking one on a 4.6 liter mustang. But I can't remember what they used as far as mounting the DP. He's not getting back from his vacation in the bahamas for another week and a half.
thanks,
Jess
thanks,
Jess
- Fredde Holmgren
- Impellerhead
looks like the exhaust has been mounted pressed against the turbine housing in some way, probably on a truck or tractor?
Fler Sponsorer sökes!
- peppe
- Skärgårds-trimmare
Sounds possible, checked at one of our big tractors at work, had maintance check today for my self. And it was a solution like the one above.phredde skrev:looks like the exhaust has been mounted pressed against the turbine housing in some way, probably on a truck or tractor?
Not exactly the same but it was kinda strange that one also.
Guess it's suppose to be pressed as you say.
- Fredde Holmgren
- Impellerhead
If you're going to use that turbine house on a car I guess the simplest is to weld a flange on.
