Sida 28 av 45
Re: Saabel Garage; Saabel Rekord
Postat: sön mar 27, 2016 5:55 pm
av keme
Dennis M skrev:Lower is "immer besser" as the commercial says!
Indeed!
Modified the downpipe and checked that how much the fire wall needs modification due engine has moved a bit back. Luckily it needs only very little cutting. Looking goooood.
Postat: tor mar 31, 2016 4:31 pm
av keme
Painted the engine bay and now it looks slightly less hidious. Next weeks plan is to put engine back in and fire it up!
Postat: fre apr 01, 2016 8:45 pm
av MickeK
Nice, looks good
Postat: ons apr 06, 2016 8:46 pm
av keme
Getting closer. Just noticed that I have to re-do the passenger side engine mount. With NG900 alternator the old engine mount doesn´t fit. Next intresting situation will be with the NG900 waterpump. Looks like that it will come very close to roll cage. Hopefully there is enough space for coolant hose.
Postat: lör apr 09, 2016 6:23 pm
av keme
Improved the gearbox breathing with R1/4 thread and a 10mm fast connector.
With new engine mounts and gearbox bracket the engine fits properly into the engine bay. Luckily that few centimeters movement didn´t cause too big changes. Previously I was thinking that I would start it up this week, but maybe next week. Few bits and pieces missing, but loooking gooooooood!
Postat: lör apr 09, 2016 6:30 pm
av Dennis M
Keep up the good work!
Postat: ons apr 13, 2016 6:40 am
av keme
Got the downpipe and pipe from turbo to cooler done. Hoping to get engine running this weekend.
Postat: lör apr 16, 2016 8:51 am
av keme
Original power steering pump didn´t fit next to turbo so it got removed. Took the grooving from 9000 waterpump and welded it on top of the NG900 pump and put a 1755mm serpentine belt to run waterpump and alternator.
Postat: lör apr 16, 2016 5:07 pm
av keme
Postat: lör apr 16, 2016 5:54 pm
av Dennis M
Postat: lör apr 16, 2016 5:56 pm
av W108
Thats nice !!!
Postat: sön apr 17, 2016 2:42 pm
av keme
Put a Mercedes power steering pump into the engine bay. Problem is that I don´t have any wiring diagram for that and I would like to get that adjustable.
All tips are much appreciated!
Postat: sön apr 17, 2016 7:13 pm
av David Herbertsson
Sounds and looks good! I´m looking forward to some test-driving videos!
/David
Postat: tor apr 21, 2016 6:11 am
av keme
David Herbertsson skrev:Sounds and looks good! I´m looking forward to some test-driving videos!
Thanks! So am I!
Had to cut bonnet a bit more because compressor housing had to be rotated. Also noticed that engine has moved a bit towards the driver side with new engine mounts.
Postat: tor apr 21, 2016 7:48 am
av dahla
Mount a transparent scoop too
