Has anyone looked at this as a cheap 6 speed box for the b230? I have an is200 box on my b230 now but its clutch pedal is quite heavy, and im wondering if going back to bmw stuff is the way.
But also i thought someone must have done it now as its a cheap nice box
bmw 118i or the likes box to b230
Re: bmw 118i or the likes box to b230
G6S-17BG - yeah, that's not really a gbx that's been explored anywhere. I have one that's going into my car - but that's no boost just M54B30. A buddy of mine has one too in his 328 but he hasn't run it yet.
Anyway, its rated at like 320Nm. I think it was 30mm longer than a S5D-250G and weighs the same as a S5D-320Z - so, it's the lightest 6-speed gbx and it has the same rating as the old M3 e36/328 gbx. Should be OK. And as you say, they are basically free since nobody rund them.
Henrik Eriksson
E46 325 3.0 - trackdays och rondellsladd
VW 1200 '64
VW 1200 '64
Where do you find specs and such for this gearbox?
Googled but found absolutely nothing about this model.
Here is the ratios of the is200 box which is on my b230 and the ratios of the bmw 120i box. Now, the is200 is amazing, but my clutch is heavy which i have found out to be the sizes of the master/slave cylinders. But you can get adapters for the b230 to the bmw box cant you? Just be interesting as these boxes in the uk are not expensive now.
is200 bmw 120i
First Gear: 3.874 4.32
Second Gear: 2.175 2.46
Third Gear: 1.484 1.66
Fourth Gear: 1.223 1.23
Fifth Gear: 1.000 1.0
Sixth Gear: 0.869 0.85
is200 bmw 120i
