Heebspeed 16v Volvo turbo
linuxman51
Inlägg av linuxman51 »
Fortfarande väntar på motordelar :doh: (Någon går kick Sten P. och be honom 'Wheres the turbobricks group buy stuff?! )
framsteg:
1990 740 gl
2003 Evo 8
linuxman51
Progress!
1990 740 gl
2003 Evo 8
linuxman51
Updates. :shock:
Busy busy busy.
the 2,5L :
test fitting, they have a new bracket now. Two 044's:
the evo's power numbers:
not bad for a grocery getter.
:lol:
1990 740 gl
2003 Evo 8
JohanK
Inlägg av JohanK »
Looking good!
What is that pipe setup under the work bench :?
Mercedesknegare
peppe
Skärgårds-trimmare
Inlägg av peppe »
Flow bench?
linuxman51
its a flow bench, that isn't hooked up right now.
car dynoed 435 rwhp with no nitrous, 512rwhp with a 75 shot, through an aw71
and went 10.8@129 mph in the 1/4 mile friday. Video will be posted in a bit.
Senast redigerad av linuxman51 den mån okt 12, 2009 6:04 pm, redigerad totalt 1 gånger.
1990 740 gl
2003 Evo 8
Da_Snake
Inlägg av Da_Snake »
Very nice but either build new enginemounts or buy new ones, the stock alu ones sometimes snap of, not fun at all..
Mpre has steel mounts if you dont want to build them.
http://mpre.se/
Fredrik Ringhald
072-316 26 91
linuxman51
I'll look in to it, it doesn't move around that much right now nor load it up that bad.
video (finally)
http://videos.streetfire.net/video/10-s ... 714020.htm
1990 740 gl
2003 Evo 8
linuxman51
Tuned the car some more (still have the aw71, so no racing)
blue line- 20psi
green line- 23psi
red line- 26psi
no nitrous on any of these passes.
1990 740 gl
2003 Evo 8
linuxman51
1990 740 gl
2003 Evo 8
nicke.t
Inlägg av nicke.t »
nice. :thumbright:
tel 0707149931
werd
Inlägg av werd »
Awesome! nice sound from it as always with 16v :) Poor headgasket :P
micke999
Förvisad
Inlägg av micke999 »
sounds angry :twisted:
ErikR
Inlägg av ErikR »
cooling problems?
http://www.projekteffekt.nu" onclick="window.open(this.href);return false;
linuxman51
ran out of gas :doh:
and blew the headgasket.
1990 740 gl
2003 Evo 8
