Saabel Garage; GMC Typhoon #FinnTyphoon
keme
Re: Saabel Garage; Saabel Rekord
Inlägg av keme »
Very short video from dyno with poor audio :D
https://www.instagram.com/p/BsGApdAIGD1/
Just before christmas I booked dyno tuning at Eduel Dynopalvelut. Rekord was running and driving so it was assumed that this was quite streight forward and relatively easy. Oh boy. First we had to fiddle with ECU settings for idle air controller, fan and boost controller, because I hadn´t pre set them. Also fan relay was broken. It said *click*, but fan woudn´t do anyting. After all this hassle we got to tuning. Too bad it ended quite suddenly because gearbox oil leaked into clutch via gearbox sealing. This was only video I got shot from dyno and the clutch slip can be heared.
Luckily there is plenty of time before summer and Rekord will be in dyno condition with little fixes.
keme
Inlägg av keme »
Got the exhaust pipe done. There was no room above the rear axle for 3.5" exhaust pipe, so it had to go under it. Made oval section of 2.5" pipe to get decent ground clearance. I am quite happy with the result.
keme
Saabel Garage; BMWega
Inlägg av keme »
Ok,
At the end of the summer I just had to buy a proper winter beater because one come for sale. Picture from last Sunday:
Opel Omega with BMW M52B28TU engine. Hell of a lot fun :D
Fitment is very good. With GS6-37BZ gearbox and 3.9 rear end with LSD it is actually quite good on a track and also on a highway. Why there is a bucket in an engine bay? Ofcourse it is for fitment!
If a bucket fits in there, then also a HX35 will fit there! Plan is to drive NA ´till the spring and then add the HX35 in the engine bay :)
keme
Re: Saabel Garage; Holset95
Inlägg av keme »
I have also this Saab 9-5 with Holset HX35.
I got it dyno tuned this weekend and put the dyno graph in Instagram : https://www.instagram.com/p/Bt_byj9lQiS/
I am happy with the numbers ; 439hp/575Nm :)
There are also few 9-5 dyno pulls in my Instagram story.
keme
Inlägg av keme »
YEY. Got Saabel Rekord running again. Have to connect the oil pressure measurement to ECU before dyno, but otherwise it would be ready.
https://www.instagram.com/p/BugriHdlWHM/
keme
Inlägg av keme »
Put in a new driver seat and made some room for air filter.
Turbo location has shifted few times so the hole is getting bigger :D
Now the oil pressure measurement is connected. Connected also fuel pressure and fuel temperature sensors. Now it would be quite much dyno ready.
keme
Inlägg av keme »
Logged oil pressure today. ~2bar@88c on 1200rpm. Should be quite much inside Saab spec for oil pressure?
keme
Re: Saabel Garage; V8
Inlägg av keme »
Bought a "full motor" for some future project. I haven´t got a chassis yet, but the price for this engine was decent so it had to be bought. It is an aluminum block 5.3 truck engine so it is suitable for quite many applications. It weights "only" ~200kg so it is quite close to D24 or 2JZ :D
https://www.instagram.com/p/BvW3U2EF2u4/
keme
Inlägg av keme »
Tweeked drive shaft a bit and now it would be dyno ready. Again. Hopefully I can get dyno time for this weekend.
keme
Saabel Rekord ; Dyno time
Inlägg av keme »
Booked dyno time for next Wednesday. Things are getting interesting :D Everything should be OK and ready for full pulls.
#500whp
https://www.instagram.com/p/Bv3YF-Ylrec/
keme
Inlägg av keme »
David Herbertsson
Inlägg av David Herbertsson »
I wish you the best of luck :thumbright:
/David
Camaro Turbo.
Kadett C Turbo.
keme
Inlägg av keme »
David Herbertsson skrev:I wish you the best of luck :thumbright:
Thank you! Maybe there is some luck next time..
This didn't go exactly as planned. Dyno result was 350whp@1bar, but engine suffered seriously low oil pressure; 2.7bar through entire RPM band. So we decided to open the oil filter. There was a lot of metal. Not good. Have to open the engine and look what is wrong. Engine itself appeared promising and 500hp will be pushed easily at the wheel. Hope the turbo is OK
Picture of the inside of oil filter: https://www.instagram.com/p/BwEuwjVHPis/
fugazi
Inlägg av fugazi »
Oooops....
keme
Inlägg av keme »
Thank you for posting the picture to this topic.
Have to try to open the engine this week.
