Tack!
Re: Tack!
Finders på turbo på min B20b dubbla Stromberg
Kan man trycka genom Stromberg?
Bill bara ha lite roligt medan Jag bygger my motor!
Inte så lätt att hitta delar här, bad rekomenders att upp graders för 150-200hk?
Tack from Down Under!
- fredde_vit_pv
Re: Tack!
Jes, you can but have to block maybe the chokes and things(bimetal cold start system etc!?) that not compatible whith boost
and grind the needles diameter at the heightof lift when the turbo starts to boost.
the needles usaly needs to be as thin as possably the 1/3 at the bottom.
if the turbo flow more air than the needeljets can provide you have to lower the boost or go to enrichment somehowe
( hope you know the higher pressure fuelsystem regulation system needs already)
just my thoughts
//F
just my thoughts
//F
- fredde_vit_pv
Re: Tack!
gissade på att du inte snackar svenska
