Saabel Garage; GMC Typhoon #FinnTyphoon
Davveberg
Saabel Garage; Rekord V8 and #740LS
Inlägg av Davveberg »
keme skrev:In case you are interested of that I would be very pleased if you would subscribe the channel.
Done and Done! Bild
⚔️Violent|Clique⚔️
Instagram: https://instagram.com/dave_vlnt?r=nametag
✖️Edge Street Customs✖️
Instsgram: https://www.instagram.com/edge_street_customs/
Volvo V90[Pebben] 1:st Air lambo edition (Sold)
Volvo 245 [V8agon] building in progress..
keme
Re: Saabel Garage #740LS
Inlägg av keme »
Huge thanks for everyone who has subscribed the channel. I´ll be doing the #740LS video this year in anycase :)
Last weekend I took the #740LS to Lapua racetrack. Loaded 16 tires in the van, but got only 10 of them burned. Begun the day with fiddling the radiator fan electrics and connecting radiator water spray system. Water spray system sounds much better than "windshield washer and water nozzle from Biltema" :D Anyway, got those sorted out and had zero heat issues whole day, though the temperature was above +25c. Only problem was the hydraulic handbrake which was not working properly. Had to pump it first once and with second pull it worked. I bleeded it, but it didn´t help.
There were few photographers at the track and one of them took this masterpiece:
https://www.instagram.com/p/Chgw8v5I-kL/
Next weekend there is a trackday at Pesämäki and I am planning to take Volvo there and burn atleast those 6 tires. Hope I find few more within the week :)
keme
Inlägg av keme »
Very short video from last Saturday
https://youtube.com/shorts/UopFvtvH5fc?feature=share
keme
Inlägg av keme »
Got to drive at Pesämäki track last Saturday on Opel 60´s & 70´s club and Opel Club Finland joint track day. Volvo just kept working and I got to shread 14 tires.
https://www.instagram.com/p/Ch1iTSADLWz/
keme
Inlägg av keme »
And short video from last Pesämäki drift session:
https://www.youtube.com/shorts/PAVfmNIU6t8
keme
Re: Saabel Garage; Rekord V8
Inlägg av keme »
Brought an engine from back yard in the garage, put a "Rekord fit kit" in it and dropped in :D
https://www.instagram.com/p/CjD1bdHo8Wp/
Engine appears to be in decent condition. Interesting to see what kind of oil pressure it has. The plan is to get Rekord in driving condition and also when the engine, gearbox and chassis are combined they tend to eat up less space :D
Engine itself was a genuine junk yard drop-out unit. It spins and appeared to have compression in all cylinders.
https://www.instagram.com/p/Ci-fV9IIdYV/
keme
Saabel Garage; #FinnTyphoon
Inlägg av keme »
https://www.instagram.com/p/CjlLcUNoVEW ... MyMTA2M2Y=
Most likely I am the worst to wash cars. Therefore, I have to take pictures in the dark :D
keme
#FinnTyphoon
Inlägg av keme »
https://www.instagram.com/p/CjxVTewomga/
Other option is to take picture from the distance :D
keme
Saabel Rekord V8
Inlägg av keme »
https://www.instagram.com/p/ClQTiTcNGD8/
The first street legal LS swapped Opel Rekord in Finland! Got it inspected few days ago :D Already waiting next summer and proper drift sessions. I have decided it will be goooooood.
keme
Saabel Garage Rekord V8
Inlägg av keme »
https://www.tiktok.com/@saabelgarage/vi ... 7224803589
Old video, but selfclaimed Fastest Opel Rekord C in the world. Any other opinions? :D
keme
Inlägg av keme »
https://www.instagram.com/p/CltNntaN1Zg/
Changing Volvo 240 1031 axle to a Ford Explorer 8.8" unit. This Ford axle is enormous and it should be unbreakable.
keme
Inlägg av keme »
keme skrev: sön aug 21, 2022 8:20 pm Huge thanks for everyone who has subscribed the channel. I´ll be doing the #740LS video this year in anycase :)
Ouch, didn´t get the video done by the end of the year 2022, but have to get it done early 2023!
keme
Re: Saabel Garage; Rekord V8 and #740LS
Inlägg av keme »
Well, the first youtube video is about fitting Saab engine to Opel Omega, but unfortunately it is only in Finnish:
https://youtu.be/b8MgWSRmZHs
keme
Re: Saabel Garage #LeilaKadett
Inlägg av keme »
I haven´t got anything done to Rekord or Volvo, because I set target to get my Kadett running.
Long story short; A year ago I bought a Opel Kadett C rolling chassis from a friend
Fitted a C18XE engine and Omega gearbox in it
Then it sat at the yard almost a year.
Then it got sand blasted and base paint:
https://www.youtube.com/shorts/n8SLEbJH3ZE
Now it is in paint and assembly phase:
Here is a bit of a transformation video :D
https://www.youtube.com/shorts/hateOEWzCMU
Target is to get his fully done in May and I am sure I get it done. Also I am very sure it will look DAMN GOOD :lol:
keme
Inlägg av keme »
keme skrev: lör apr 15, 2023 7:47 pm I haven´t got anything done to Rekord or Volvo, because I set target to get my Kadett running.
Change that target to June which should be quite reasonable because there is almost just finishing touches left. Although the list is not the shortest one.
Got the chassis wiring mostly done. For the first time I thought to do it properly at the first try and therefore I bought Raychem wire from TT-Speed. Have to say it was a good decition. Got a lot of different color wires and the wire was nicer to work with than regular market wire.
Engine bay is also mostly done. Have to extend few wires and finish the cooling system.
This is what I am very pleased with:
Got new roof liner fitted! Damn it looks good!
