Sida 2 av 47
Postat: tis jun 22, 2010 9:57 pm
av keme
Some paint on wheels. Those 8.5x17 wheels look a lot better than original 7x17. Seams that I have to get that 7x17 pair also widened.
Postat: mån jul 26, 2010 7:14 pm
av keme
Postat: tis jul 27, 2010 7:57 am
av Edvard
I really like your project! I am building a Ascona A with a saab b234 and schwitzer s200.
Where did you buy your adapter plate?
Postat: ons jul 28, 2010 8:14 pm
av keme
A friend of mine made few of those adapter plates. He spotted the drawing for that plate from
http://www.lowbudgetrides.com/
Postat: tor sep 09, 2010 2:01 pm
av keme
Something again
Before
After
Postat: mån okt 25, 2010 8:07 pm
av keme
Didn´t have anything better to do today, so I removed balance axis chain and painted the engine.
Before
After
Postat: mån okt 25, 2010 8:36 pm
av David Herbertsson
Cool car and it´s looking mean!
/David
Postat: fre okt 29, 2010 9:58 am
av keme
Thanks David.
Yesterday I bought adjustable camshaft gears. Still missing better camshafts and better valve springs. Then the engine would be ready.
Postat: fre okt 29, 2010 4:24 pm
av Ken-1
Looking good!
For valvesprings volvo 9135130 are commonly used in Saab engines, not too expensive if I remember correctly.
Better cams can be hard if you are on a budget, folkraceshopen in Sweden has some cams but the quality of those I have no idea about.
http://www.racestuff.se/motor/kamaxlar-c-170-1.aspx sells cams and others for about the same price. Not very cheap...
If you have an old 900 or 9000 around you can take the cams from that, a bit more duration and lift but not much.
Good luck with the build othervise, are you planning on running T5 for engine management?
/Kenneth
Postat: fre okt 29, 2010 5:25 pm
av keme
Yeah, I am planing to uset those Volvo springs. Camshafts I have thought Enem products because anyway camshafts will cost money and those seam to work rather well. Those older Saab camshafts are so little better, that they are not worth trying.
I am not going to use T5 engine management, though it would propably work ok. I have Tatech Pro32 engine management system.
http://www.tatech.fi/index.php
Postat: lör okt 30, 2010 11:04 am
av mista
Varsin komea kampe.
Sick wheels
Postat: tor nov 04, 2010 10:19 am
av keme
Added a little more iron to roll cage because I am going to do lighter doors to this.
Postat: mån nov 15, 2010 10:18 pm
av keme
Weighted the original doors and scale stopped at 28kg each! I am aiming to make those atleast 10kg lighter. Hood weighted 18kg and fiberglass hood should be also atleast 10kg lighter.
Empty door with hinges ~8kg.
Postat: fre nov 26, 2010 4:42 pm
av keme
First version of polycarbonate windows. I made those from plywood because it is much cheeper to practice
Hopefully I get my polycarbonate pieces next week and also manage to fabricate and assemble them.
Postat: lör dec 04, 2010 5:04 pm
av keme
Assmbled safety tank
Rear windows are done, but I am still waiting pieces for front windows.
