Sida 2 av 2
Re: HX40 with variable twin scroll exhaust housing
Postat: fre dec 31, 2021 1:36 pm
av Stefan Ingi Jonsson
Allx skrev: ↑fre dec 31, 2021 10:14 am
Yep! You were talking about that in the thread but I didnt know it was called a spoolvalve
I honestly don't know what too call all of these valves hahaha
Postat: mån jan 03, 2022 12:56 pm
av Pacman
Borg Warner showed this at Sema 2014:
Postat: mån jan 03, 2022 1:42 pm
av Kadett4wd
Koenigsegg har väl också?
Postat: mån jan 03, 2022 4:43 pm
av TurboRickard
Här är ett videoklipp från Elmer Racing där han beskriver ventilens funktion och redogör för deras tester dom gjort.
https://www.youtube.com/watch?v=7qJ4XGaO5jk
Sen så har Felix på Ppf byggt något liknande för några år sedan som fungerade väldigt bra.
Se bifogade foto.
- Felix.jpg (97.67 KiB) Visad 5468 gånger
- Felix 2.jpg (65.39 KiB) Visad 5468 gånger
//Rickard
Postat: tis jan 04, 2022 4:59 am
Pacman skrev: ↑mån jan 03, 2022 12:56 pm
Yes I already posted a link about this turbocharger;
https://www.motorauthority.com/news/110 ... -of-turbos
You can preorder an exhaust housing from;
https://turbosource.com/products/turbos ... ne-housing
Do you think it's possible to modify a HX40 exhaust housing like this?
What metal is best for the valve?
How well does the valve need too seal between the scrolls?
Any thougths?
Postat: fre jan 07, 2022 8:41 am
av Leiffi
BW type is only type that might work , DPUK type that some americans also make is the stupidest thing I have ever seen.
Maybe 15 years ago almost every truck racer in Finland tried "spool valve" but there is a reason no one is using it anymore.
Postat: fre jan 07, 2022 11:35 pm
av Allx
Leiffi skrev: ↑fre jan 07, 2022 8:41 am
... almost every truck racer in Finland tried "spool valve" but there is a reason no one is using it anymore.
Why? I had planned to try that with a new manifold for a big turbo RB26
Postat: lör jan 08, 2022 5:20 am
Allx skrev: ↑fre jan 07, 2022 11:35 pm
Maybe the reason why the conventional spool valve is not used often is because it chokes the engine to much at low rpm and cannot spool the turbo with enough efficiency so you lose to much torque trying to create torque. This is a shit explanation but hopefully you get my point.
Postat: lör jan 08, 2022 9:17 pm
av Allx
I have a SXE 364 with 80/73 turbine. I cant imagine it choking up on 400 hp and 1.01 housing with spoolvalve closed. Not that difficult if it doesnt work and have to change the collector.
Postat: lör jan 08, 2022 10:35 pm
av Leiffi
Stefan Ingi Jonsson skrev: ↑lör jan 08, 2022 5:20 am
You need open exhaust manifold with divided housing , that already is very stupid, you lose the benefit of divided housing , then you add that valve to hurt flow efficiency even more. Yes, it might make more boost down low but it makes even more backpressure = no power.
Postat: ons feb 16, 2022 11:04 am
Postat: ons feb 16, 2022 12:12 pm
av fulsnut
I hopes it works
(Bad english)
Postat: sön mar 13, 2022 5:46 pm
Postat: lör apr 15, 2023 11:50 am
av AntonD
https://youtube.com/shorts/zvTdue0Gra4?feature=share
https://youtube.com/shorts/YqfyXGvIKvU?feature=share
A proper setup works better than a quick spool valve.
But in my case, i have ha 6.5td v8 were the crossoverpipe goes into passenger side manifold. cyl no8 doesnt like that with stock turbo making 2:1 backpressure at 15psi so i put on a hx40 and lost all spool.
So, i made a very crude looking qsv, but it still works.
Gives me boost 3-400rpm earlier, where I need it. But it builds backpressure fast if it opens late.
