I will say that ultra high static cr results in theory somewhat smaller cylinders when compared to same engine with heads with bigger combustion chambers. Incoming air-fuel mix have a mass, actually is quite large, but anyway it can fill cylinders with over 100VE% and if that occurs, so we will get a situation that in engine with bigger combustion chambers aka. lower CR will get more af mix inside of it, compared wit same engine with cylinder head with smaller combustion chambers aka higher cr.
And this is static, actually engine is running with dynamic cr and it depends so much at the camshaft that i don't go to it now...
Compression ratio and volumetric efficiency.
Re: Compression ratio and volumetric efficiency.
In my RB26, I have no squish at all. They are completely removed and the chambers looks like a HEMI and I think i have around 7.0:1 CR.
With 264 inlet and 272 exhaust cams with 8.5mm lift and a GTX4088 turbo I make over 700 whp at 1.6 bar of boost.
Compared to my friends RB26, with stock head 8.5 CR and 9.5mm cams, mine makes around 100 hp more at the same boost level
- Stefan Ingi Jonsson
- Lite mer laddtryck
Thats very interesting, do you have more specs on the motors and setup?Allx skrev: ↑lör nov 23, 2024 7:40 am In my RB26, I have no squish at all. They are completely removed and the chambers looks like a HEMI and I think i have around 7.0:1 CR.
Just forged bottom ends and slightly ported heads. Same manifolds and very similar turbosStefan Ingi Jonsson skrev: ↑mån nov 25, 2024 10:22 pmThats very interesting, do you have more specs on the motors and setup?Allx skrev: ↑lör nov 23, 2024 7:40 am In my RB26, I have no squish at all. They are completely removed and the chambers looks like a HEMI and I think i have around 7.0:1 CR.
