Saabel Garage; Chevy C1500 Pickup
Re: Saabel Rekord C -66
Hi,
The fuel pressure sensor shown in picture above, what brand / type is that?
BR
S-A
BR
S-A
Eik Grønt
Norge
Norge
Hi,RampagE_740 skrev:The fuel pressure sensor shown in picture above, what brand / type is that?
It is Bosch 0261230112 http://industrial.boschautoparts.com/Te ... 230112.pdf
Pressure measuring up to 10bar and temperature measuring -40 .. +125 celsius
Re: Saabel Garage
Though I bought a 1.7s engine which had been running this summer, I put back the original 1.9s engine because I just didn´t have the energy to swap rekord-fit oilpan from 1.9s to 1.7s. Interesting to see if this engine works. Usually there is some reason why engine gets removed from car and car ends up to be looooooooooooooooooooooooong project
Re: Saabel Garage
Saabel Rekord
Got brakes (except handbrake) working today from Caravan. Now though I am going to put this on hold for the rest of the month, because I have to get Sedan dyno ready. Booked dynotime on 27th day morning and on afternoon there is trackday at Ahvenisto where I am going. Hoping to brake that 500hp on dyno
That should be realisticly possible.
Re: Saabel Garage
the stationwagon looks race redy !
Re: Saabel Garage
moaaaaar boooooooost
Re: Saabel Garage
Re: Saabel Garage
Today didn´t go exactly as planned. I went to the dyno and then straight to home. At the dyno hose from intake manifold to wastegate got loose in full pull. Boost peaked suddenly somewhere 2+bar and after that engine started to make some knocking sound and we put Rekord back to the trailer. Quesses for broke parts are con rod bearings, main bearings or piston.
Well, have to open that engine and see what has happened.
Re: Saabel Garage
Compression pressure test showed that there is ~8bar in every cylinder, so pistons seem to be OK. Con rod bearings are next suspect.
https://www.facebook.com/photo.php?v=10151891730917342
Short video from dyno before extra-engine sounds.
Re: Saabel Garage
Drained oil from engine and shiny copper bits came out from engine. So, bearings are done.
