Sida 3 av 4
Re: why is my engine not powerful?
Postat: sön jan 05, 2025 9:44 am
av Matti johansson
Do you run on tps (alpha n) or vacuum (map)
If you run Tps that ignition table wont give you any nm.
Too small numbers around 3000rpm.
Did the tuner use any knocksensing device?
With that camshaft and singelthrottleblade. I would go by TPS not map, it would be too erratic.
And choose a good tps, not the bosch Volvo 850, that is also too erratic. Bmw have one with internal return spring that gives solid readings.
What afr or lambda did he aim for, and did he reach it?
Tell him that you want afr or lambda readout on dyno sheet.
/Matti
Postat: sön jan 05, 2025 10:02 am
av bmw2101
its on map sensor, and it is a bmw one! he was aiming for 14 afr i think, i did get a print out but i never kept it. Im not sure how he does knock sensing but he is a really good tuner, quite well known over here.
i think that cam is a low quality one, is that the problem?
Postat: sön jan 05, 2025 3:04 pm
av Matti johansson
no, its not lowquality.
just a lowpricecam that probably dont do youre engine right.
you see when looking at youre ign table i dont know what ign it gets when on map since it migt be a restriction in the intake and then it moves to more vacuum at rpm.
but i think youre engine will take about 30degrees(probably more when 11:1) from 3000, and it does not get near that what i can see. so i think you have more to get out of it.
volvos are not so sensitive and what i see the inj table is more "modern" than what this engine wants. think more litke a distributor!!
how long time did the first dynosession take?
Postat: sön jan 05, 2025 7:44 pm
av bmw2101
it is strange but he said he defo wanted to use the map sensor as itll run smoother. I was also told by someone over here who also runs a rolling road, that the plenum style setup i have [the kjett with injectors welded into it and a 63mm inlet] and a 300deg cam do not go together. That is why i was really interested about the H cam.
Chris had the car for maybe 1.5 hours on the rollers, but it was a running car when he got it, he has mapped it maybe 8 times before with different set ups.
It at one point had a t4 cam in it, and it had a lot less power, it had the lh 2.4 style inlet then, and it pulled strong all the way threw, worked really well. thats the power i need, not top end..
Postat: sön jan 05, 2025 10:11 pm
av Matti johansson
Well, maybe the cam will do the job, but i dont think the ignition is fully tested. Maybe uptop. But if you get the midrange up maybe you e got a killer!!
I would have aimed for 13,2 afr. And tested more ignition.
On dyno if youre unsure. Do 26deg stiff from 3000 and up, do 2-3 runs. Then test +2deg and see the different. Then do +2 again and youll se when it doesnt gain as much, then youre getting close.
And if youre curious, connect to megatune and show rpm, map and ignition (if you have afr show that to).
Put it in high gear and film steady with telephone.
Then we will se what ignition it gets, if the intake is restricting, and if it gets fuel.
Postat: mån jan 06, 2025 9:25 pm
av bmw2101
right ok, im going to take the car out on saturday. I can do a log and ill play it back threw megalog viewer, and you can see how the ignition is when i drive. Looking at the table, and roughly guessing i think it is about 25 degs mid range, but i am only guessing.
I do have a lambda but it isnt reading correctly, it must need calibrating or something, it is miles off.
Postat: tis jan 07, 2025 6:20 pm
av quattro
Matti, would you say this power/torque curve is typical for a Volvo B23 original VOC rally engine?
https://www.dwautokonsult.se/voc-crossk ... mappning-1
As far as I can tell it's showing power at the wheels.
If that's the case, then max power is about the same - and at the same rpm - as the engine in this thread
But the torque curve is looking much better. Hardly any dips at all, just a fairly small one at 3300 revs.
It points in the direction of the cam. It has too much duration for the engine set-up.
And I think you are right about the ignition as well.
Postat: tis jan 07, 2025 9:40 pm
av Matti johansson
His whp is in my dyno engine hp. so a voc at 154-160 ehp is fairly normal.
There is a chanse that the cam can work even with much duration, and that is because of restricted intake, it wont make maxhp, bur it will be a long curve wich sometimes kan be easier to drive than a stron engine with short curve
Postat: sön feb 16, 2025 7:59 pm
av bmw2101
Matti johansson skrev: ↑tis jan 07, 2025 9:40 pm
Matti, i did a rally last night with the car, it was ok but the engine is totally wrong. I do a lot of say second gear 2-3000 into and out of a corner , then need it to pull. The t5 is ok but it dosnt have much low end grunt. i had a t4 cam before that was much better, should i put a t4 or should i go for a factory cam?
Postat: mån feb 17, 2025 12:39 pm
av Matti johansson
if you liked the T4 go for that, but a try athe H cam might be succesful. even if that cam suffer on rpm.
Postat: mån feb 17, 2025 9:39 pm
av bmw2101
Matti johansson skrev: ↑mån feb 17, 2025 12:39 pm
do you have a print out of an engine with a H cam in it that is similar to mine? looking back at my print outs of rolling road sessions, the best the engine was as in for driving was with a t5 cam, 531 head i ported myself, with standard valves on a cast manifold. but mid range the power dipped, and went back up. i am thinking maybe the H cam would be nicer for me but make less power overall. i need it to drive well from say 2500-5500 and pull mid range hard, that is where it dips now.
there is also the kl racing t3 cam that looks maybe good for me too
thankyou for your help
Postat: tis feb 18, 2025 9:16 am
av Matti johansson
if you look above at DW´s top graph that is an unported, cast manifold, cast exhaustmanifold, with airflowmassmeter, little higher compression, Hcam, freeflowing exhaust. standard valves.
Dont look at the numbers, cause dynos differ. but look attt how the graph looks. i think the last rpm in graph is 7000. and 1000rpm between each number.
H is not a bad cam! good for midrange. and installheight from 2,4mm(rpm) to 3,6mm(torque) you can try what you like.
Postat: ons feb 19, 2025 9:26 pm
av bmw2101
thanks for your help mate, i have bought a H cam from speedyparts, hopefully itll be here soon and i can get it in and see what its like.
i cant wait to get back out in the car, its been too long, i had forgotten what its like to drive it,
Postat: tis feb 25, 2025 9:05 pm
av bmw2101
My H cam is here!!
what should i time it in at at tdc for my rally style? needs mid range, less of a focus on top end.
thanks
Postat: fre feb 28, 2025 1:11 pm
av Matti johansson
between 2,8 and 3,6 mm open inlet at tdc.
2,6 is rpm and 3,6 is lessrpm and more torque.
start with 3,6mm.
/ Matti
