Saabel Garage; Chevy C1500 Pickup
keme
Re: Saabel Garage; Rekord V8 and #740LS
Inlägg av keme »
First street legal LS swapped Volvo in Finland! And it looks like all the rest of them :D
https://www.instagram.com/p/CL3iEgCB9fl/
Markus
Inlägg av Markus »
Congratulations! Good time for installing some turbochargers? 😊
keme
Inlägg av keme »
Markus skrev: mån mar 01, 2021 6:29 pm Congratulations! Good time for installing some turbochargers? 😊
Yes it would be, but I really think that I´ll be going N/A for the start :) I have 6.0 parts in the garage and I might slap that together in the early summer.
keme
Inlägg av keme »
Put the LS swapped 740 on the scales. 5.3 LM4 i.e. aluminum block engine + BMW 5 speed ZF, battery in the trunk and ~30L gasoline in tank = 1433kg. I think it is quite decent weight for this pig.
https://www.instagram.com/p/CMAAlCgB9BZ/
It is interesting to see how the weight changes after I put a 6.0 engine and 6 speed gearbox in this. Engine is 45kg heavier and gearbox adds maybe 10kg. So thats about it :D Not very difficult calculation after all :D
keme
Inlägg av keme »
Quick recap from latest modifications.
After inspection I noticed crank rear seal is leaking. Only way to replace that was to lift out the engine and gearbox, because it is impossible to remove gearbox from engine in the car. This offered a great oportunity for some tuning. I had a 6.0 liter LQ4 engine in the garage, a set of 243 cylinder heads and a 227/234 cam. Heads needed valve lapping and 0.25mm surfacing due some dents. With these heads the stock LQ4 compression ratio is changed from 9.5 to about 10.2. Also I put GTO LS1 accessories to this engine.
5.3 engine with truck accessories on the floor and 6.0 with GTO accessories on the engine stand. GTO accessories made the upper water hose much easier and smoother. Also dropping the alternator down gave hood clearance and made engine bay look a bit cleaner.
"while I was at it" I changed the gearbox from GS5-39DZ to GS6-37DZ. Old gearbox whined a lot and also I wanted that 6th gear which is overdrive.
Had 26x9.5 slicks in the garage, so they had to be tested :D I don´t know though if the stock rear end would be strong enough for those...
keme
Inlägg av keme »
Got the rear diff changed to a refurbished LSD. Found out also why this felt quite short geared and responsive: It has 4.1 final gear :D I´ll probably change that to a longer one but have to test it first.
keme
Inlägg av keme »
Got the rear suspension upgraded
Now it should be as good as it can be in stock form. Next step is to put a Ford 8.8" rear end with some sort of suspension arms. Maybe four link. I already bought one axle because I got a bargain on it :D
keme
Inlägg av keme »
Took second scaling on this. Now it has iron block engine and a GS6-37DZ. Not a surprise that the weight difference is quite much the weight of the blocks.
https://www.instagram.com/p/CQBg0bghirL/
keme
Inlägg av keme »
Got to drive a bit. Car felt good. GS6-37DZ gearbox and 4.1 diff ratio felt very good on that short track. I think with zero ackerman and with a little more steering angle it will be a lot of fun.
https://www.instagram.com/p/CQnaVGwhyu4/
It was fun until it lost the oil pressure.
https://www.instagram.com/p/CQp3Hn8hd2e/
I don´t get how the rocker arm bolt had got loose. Well, now I have to build a new engine.
inken
Inlägg av inken »
kul bygge,
keme
Inlägg av keme »
Built another engine and got to test drive it. Drove the Volvo to the track, roasted four tires and drove back home. Kinda success after all the difficulties.
https://www.instagram.com/p/CTwUArvoWOg/
Next track day is this weekend. Before that I have to change drive shaft seal and make few adjustments to get the car feel a bit better.
keme
Saabel Garage #740LS
Inlägg av keme »
Last weekend I visited on grassroots drifting day in Kaanaa. Had a lot of fun and Volvo worked decently.
Here is a short video of the day.
https://www.youtube.com/watch?v=YhBS8gPepLQ
keme
Saabel Rekord V8
Inlägg av keme »
Started to prep the Saabel Rekord for inspection. The plan is to get it inspected with an LS engine with in a month and the full road legal inspection at the spring.
Found also old Youtube video of the best quarter mile pass I have driven with the Rekord. :)
https://www.youtube.com/watch?v=hzfukdpo0t0
keme
Inlägg av keme »
As a joke I painted Rekord engine gold, but I really like how it turned out. Loooking goooooooood
https://www.instagram.com/p/CX8x5rsowUp/
Thunderbo1t
Inlägg av Thunderbo1t »
Nice! :thumbright:
