Saabel Garage; Chevy C1500 Pickup
keme
Re: Saabel Garage; #740LS
Inlägg av keme »
Hmpfff... Not exactly the start for the year I was hoping for. Volvo engine had frozen earlier and now the block has been cracked. So, I have to first change engine to Volvo and then get back to the Rekord. On the positive side: Changing the engine to Volvo is quite easy and dropping in the Rekord engine is also very streight forward :D
https://www.instagram.com/saabelgarage/p/CYKb92PIlNA/
keme
Re: Saabel Garage; Rekord V8
Inlägg av keme »
Yesssss, got the Rekord in the garage.
https://www.instagram.com/p/CZ9zhsXoE9w/
It should be running this week. Problem is that I don´t remember what parts I have borrowed from it to other projects. Interesting to see :D
keme
Inlägg av keme »
Had to take Volvo to the road inspection. Now I can drive with it one more year :D Passed the inspection with flying colors.
https://www.instagram.com/p/Caj8UyZIi_I ... =copy_link
Next I have to get back to Rekord and make it also ready for inspection.
keme
Re: Saabel Garage; #LeilaKadett
Inlägg av keme »
Well, Volvo needs yet some fiddling before dyno. There appears to be some sort of coolant flow problem in it, because lower coolant hose from radiator stays quite cold. Should try if removing thermostat would fix the problem and after that try to find working thermostat.
Rekord is as is and nothing has happened to it. Should prep it for inspection, but haven´t got anything done.
After all the "haven´t got anything done" I bought yet another project. Friend of mine put his Kadett C for sale and after a short thinking I bought it. Rust free rolling chassis and it was missing just radiator, engine and gearbox. It just had to be bought :D Now I have already fitted a Opel 125hp C18XE engine with Omega gearbox in it. Next I should drop the axles and lightly sandblast the bottom end, paint it, assemble and get in driving condition. This also needs to be inspected because last time it was road worthy was in year 2008.
https://www.instagram.com/p/CcPe-w0IySS ... MyMTA2M2Y=
Cassius
Re: Saabel Garage; Rekord V8 and #740LS
Inlägg av Cassius »
Do you now what bodykit that Kadett has?
Audi V8 -91, med RS4 B7 V8
keme
Inlägg av keme »
Cassius skrev: tis apr 19, 2022 5:40 am Do you now what bodykit that Kadett has?
I have no idea. Maybe some sort of Opel Ascona B 400-fender kit?
Cassius
Inlägg av Cassius »
Heavily modified in that case.. The Ascona kit is much boxier.
keme
Re: Saabel Garage; Rekord V8, #740LS, #LeilaKadett and Typhoon
Inlägg av keme »
Cassius skrev: tis jun 14, 2022 6:41 am Heavily modified in that case.. The Ascona kit is much boxier.
I think you are right. I asked from previous owner and Lapuan lasikuitu in Finland has done those fenders.
And while we are in the subject of boxy: my latest purchase https://www.instagram.com/p/CenWC8kovqb/ :D
Interesting which of these projects gets first inspected; Kadett or Typhoon. Kadett needs quite much work and Typhoon might be ok if I just put Maxxecu in it. I am drowning in unfinished projects...
keme
Inlägg av keme »
https://www.youtube.com/user/elceimo/videos
My youtube channel with few videos. The plan is to make video next weekend in Kaanaa with #740LS Volvo. Tires have been set on wheels and Volvo needs just small repairs.
Hope weather stays nice so it wouldn´t be just sliding in the rain.
keme
Re: Saabel Garage #740LS
Inlägg av keme »
https://www.instagram.com/p/CfO_7aGIBvn
Short IG Reel https://www.instagram.com/p/CfSAcuToVr1/ Or YouTube https://www.youtube.com/shorts/OxW-7lJEISc
Got the #740LS to the track and it worked quite much perfectly. Handbrake has most likely some cylinder stuck and therefore it didn´t do anything. Othwerwise I got to burn ~12 tires and Volvo needed just little cooling in between rounds. It was a bit surprise because weather was +27c. I have come in conclusion that this LS waterpump doesn´t move coolant at idle at all, but with 2500+ rpm it does the job. For the next time I have to make cool air intake for air filter, some sort of waterspray system to radiator and fix the handbrake. Then it is a fullsmul time again :D
keme
Saabel Garage #FinnTyphoon
Inlägg av keme »
keme skrev: fre jun 17, 2022 11:29 am And while we are in the subject of boxy: my latest purchase https://www.instagram.com/p/CenWC8kovqb/ :D
Got the Typhoon inspected and it is now road worthy after over 10 year hibernation! Although it is now road legal it most definitely needs new engine management. Current one has some perfomance chip in it and it just doesn´t work properly. Maxxecu race and new wiring harness will fix all the problems.
https://www.youtube.com/user/elceimo/featured
keme
Inlägg av keme »
Took the #740LS to the quarter mile and it went quite well.
14 passes and six of those were in the 12´s. The best time was 12.82s/180kmh. 5th gear rev limiter hit just at the finish line, so trap speeds were all 180.9kmh :)
https://www.instagram.com/p/CgFUyEVoOAu ... MyMTA2M2Y=
keme
Inlägg av keme »
Short #740LS video from midsummer drifting:
https://www.youtube.com/watch?v=eBAtO8vNv2A
keme
Inlägg av keme »
I am planning to do a rundown in English on #740LS build in YouTube, but not before my channel has reached 100 subscribers. So, the bar is very low :D
In case you are interested of that I would be very pleased if you would subscribe the channel.
I have been a subscriber on your channel for a long time :)
