Saabel Garage; Chevy C1500 Pickup
keme
Re: Saabel Garage; GMC Typhoon #FinnTyphoon
Inlägg av keme »
fulsnut skrev: lör sep 14, 2024 10:39 am Maybe it's your luck you didn't drove to Gatebil.
Better next year after a winter with dynotests. :hey:
And it's a very nice car, perfect for a hot summernight.
Have to say you are correct about the Gatebil. Luckily there are plenty of Gatebil´s to come and I am very sure I´ll get to drive this to some event.
Started the winter season today. Hope I get the engine lifted off next week.
keme
Inlägg av keme »
And the engine is out. Next it goes to engine stand and gets completely disassembled.
keme
Inlägg av keme »
Almost got the engine disassembled. Didn´t have proper damper tool so I couldn´t get yet the crankshaft and cam removed, but it will be properly torn apart this weekend.
keme
Inlägg av keme »
Got the engine disassembled completely.
Otherwise engine looked decent, but the end bearing looks a bit odd. Like it would be very worn, but still it doesn´t look like it had been destroyed just now.
Also camshaft looked a bit weird. It had almost flat spots where the lifter "goes up" on the lifter ramp.
Have to think a bit if I ditch this cam and buy "some V6" cam from Rockauto at 70$ price. I am pretty sure any cam would work decently.
Thunderbo1t
Inlägg av Thunderbo1t »
Melling (and others) sell the Syclone/Typhoon cam as a stage one performance cam, with a steep mark up so $77 seems like a bargain, and i guess "some V6 cam" will be smaller.
Elgin E-1033-P
Federal Mogul CS-1051M
Mahle/Clevite 229-1881
Melling 22119
keme
Inlägg av keme »
Thunderbo1t skrev: lör okt 05, 2024 8:04 pm Melling (and others) sell the Syclone/Typhoon cam as a stage one performance cam, with a steep mark up so $77 seems like a bargain, and i guess "some V6 cam" will be smaller.
Elgin E-1033-P
Melling 22119
This 77$ cam appears to be quite close to these. Also I am going on a budged, so I am also looking for reasonable pricing :D
The cam looked somewhat machined and it had some kind of coating on it. So, today I measured 0.050" degrees and lift of it.
Typhoon stock cam specs;
* '91-'93, ZR9/Z79, Syclone/Typhoon
- Lift (I/E) - .351/.386
- Dur @ .050 (I/E) - .179/.195 (Ductile)
Specs for this cam:
lift .372/.393
duration 180/196
All in all stock cam with little extra lift.
End result is that I have to order 77$ cam from Rockauto, because it has more duration and lift than this :D
https://www.rockauto.com/en/moreinfo.ph ... 60&jsn=342
keme
Inlägg av keme »
Got the cylinder block back from machinist, few parcels from Rockauto and washed the bottom end parts. Plan is to get bottom end quite much assembled tomorrow.
Week ago I had to try if my Rekord still starts. It did! Had to make new fuel lines and somehow there was water in few cylinders :shock: Took off the spark plugs, rotated engine, put spark plugs back and started it :) Have to say it is not fully drivable, but hopefully some day it will be again in full beast mode 8)
https://youtube.com/shorts/-pTCCLlJoBc?feature=share
fulsnut
Inlägg av fulsnut »
Is it a budget issue that you don't try a rollercam or give it too little?
And do you have any theory why connecting rods and main bearings have these damages?
keme
Inlägg av keme »
fulsnut skrev: fre nov 01, 2024 8:30 pm Is it a budget issue that you don't try a rollercam or give it too little?
This is a roller lifter cam and I am going on a budged, so it it what it is. My horsepower target is 350-400hp, so it doesn´t need much. Also with this cam the turbo should spool up nicely.
Today I got the parts kind of fitted into engine bay. It looks like everything is going to fit, but it is a bit of a squeeze :D
fulsnut
Inlägg av fulsnut »
Missed that it was a roller lifter cam, sorry. :doh:
Incredibly impressed that you have already assembled the engine and got it down in the car. :shock: :thumbright:
keme
Inlägg av keme »
fulsnut skrev: ons nov 20, 2024 2:03 pm Missed that it was a roller lifter cam, sorry. :doh:
No worries :)
fulsnut skrev: ons nov 20, 2024 2:03 pm Incredibly impressed that you have already assembled the engine and got it down in the car. :shock: :thumbright:
Thank you! Target is to get it back in running condition before christmas.
Removed the aftermarket intercooler and I am going to put back the stock air-water-cooler with a Honda Civic radiator
Had compressor housing, turbine housing, radiator and that Honda Civic radiator visiting welder. Slight modifications to all of them.
Then I performed some modern art and got the turbo+wastegate fitted in engine bay. Also the down pipe is in decent shape.
keme
Inlägg av keme »
Go all fitted and now it was time to remove all for the final assembly. I have to make a bit of heat protection, bolt all in for good and start the engine :) Target was to get this started before Christmas, but ToDo-list appears to be a bit longish so the start up will happen at early January.
IrmscherRekord
Inlägg av IrmscherRekord »
That text "Vakio" on HX40 or similar is funny. Maybe it is for the inspector at yearly MOT-test.
jävla finne med skrotbilar
keme
Inlägg av keme »
IrmscherRekord skrev: sön dec 29, 2024 10:42 am That text "Vakio" on HX40 or similar is funny. Maybe it is for the inspector at yearly MOT-test.
Yep :D It is HX40 with #18 turbine housing. I suspect that it is easier to get proper paper work prior inspection, because I really think this doesn´t pass even though it says "stock" on it :D Just a joke
keme
Saabel Garage; #PickupPerjantai
Inlägg av keme »
Had to put Typhoon on hold for a bit although it is pretty much drivable. It is missing a bit of tidying up wiring and few hoses. Drivable but not 100%. I am pretty sure I get it in full driving condition this summer.
I begun a C1500 project. "quick and easy" as always :D
I am not sure how well Youtube does translated subtitles for the videos, but there is a link to video at the end of this post.
Video description; what I am going to do with this car and put it on scales.
#PickupPerjantai #c1500 #SaabelGarage
Link to video: https://www.youtube.com/watch?v=ndXIYarKhzc
