Will the the vented discs of a 240 fit on a 160E frontaxle? I have looked up the dimensions and they look quite the same to me. I just don't have a 240 so I can't investigate it myself.
//Koen
bromsar 240 => 164?
- koenvbr
Yes I meant the frontaxle, I understand everything that u wrote. I guess you mean that I have to drill the holes in the 240 calipers a little bit bigger.larsat skrev:i asume you mean the front axle?
it will fit with the 240 calipers if you take up the holes in them a little & plane them a bit... i don't have the exakt measures, sorry, but it will fit with some modifications!!
i hope you understand
I looked at the rear axle today and saw that a 240 caliper also could fit when the holes are drilled bigger. Only problem I think is that the hole for the handbrake is bigger in the 160 discs. And the metal plate for the mud will get in the way when placing 240 discs, I think
Info about rear axle is also welcome
Thanks
//Koen
- koenvbr
I found vented discs and calipers from a '91 GLT today, so I can begin with this swap on the frontaxle next week.
Than the rear braking system:
Handbrake system from a 240 won't fit I just saw. Placing a 240 disc on the stock 160 system isn't possible either. I do saw in some brake catalogs that the discs from a '75 160 have the same number as the discs for the 240. Anyone knows what the difference is between these? I only can imagine that the '75 160 has the same handbrake system as the 240. But what about the bolts for the driving shaft then. Cause these bolts are in the way of brakeshoes...
Hope you people understand what I'm trying to say here
//Koen
//Koen
- koenvbr
I meant vented 240 discs in the front and solid 240 discs in the rear. Sorry for my change of subject with that.larsat skrev:i don't understand everything and i have never thought about putting vented disks on the rear axle
I do figured out today that the '75 160's have the suspension of the first 240. It also has metric bolts etc.
by the way...
Nice car
