Sida 39 av 45
Re: Saabel Garage; Saabel Rekord V8
Postat: mån dec 23, 2019 6:28 pm
av keme
Next I should fit the Maxxecu Spaghetti monster in to the engine bay.
Postat: tor jan 02, 2020 8:11 pm
av keme
Postat: tor jan 02, 2020 9:26 pm
av jonas landin
Postat: sön feb 16, 2020 6:42 pm
av keme
Got the exhaust system done. Bought a set of C5 Corvette manifolds, mated it with 2.5" pipe and jammed in 3.5" collector. Should be good for mildly cammed 5.3 LS
Driver side exhaust pipe goes over the gearbox because that way it doesn´t eat out the ground clearance.
Had to relocate coils because there were no mounting points in new valve covers.
Postat: ons feb 19, 2020 8:53 pm
av keme
Decided to fit the hood...
It required a bit of cutting
Just a bit through
Luckily this is not a show car. Have to fiqure out later a bit of something for the old turbo hole
Postat: tis mar 31, 2020 6:40 pm
av keme
Weighted the LS. Aluminum block 5.3, no starter, flywheel, power steering pump or liquids ; 182kg. Not bad!
Postat: mån apr 13, 2020 5:15 pm
av keme
Got Corsa powersteering assembled.
Also put new radiator in place. It is some Nissan S14 aluminum radiator and biggest that could be fit decently. Radiator cap is about 1cm from the bonnet.
Postat: sön maj 24, 2020 8:22 pm
av keme
Wiring harness quite much ready, coolant lines quite much ready. Looking goood
I don´t know if it is possible to build car in Scandinavia without Volvo coolant expansion tank
Saabel Rekord V8 started
Postat: mån jun 08, 2020 2:22 pm
av keme
Postat: mån jun 08, 2020 2:43 pm
av * * * NXJ * * *
Nice
NXJ
Postat: tor jul 02, 2020 9:59 pm
av keme
Drove the first meters!
https://www.instagram.com/p/CCJ0bDthECM/
Few minor problems; clutch is not engaging fully, 2&4 gear is not engaging (gear stick issue) and there are few coolant leaks. So, all in all quite good
Postat: tis aug 04, 2020 8:34 pm
av keme
Clutch started working when I adjusted clutch pedal and got more throw to cylinder. With previous SRE754 it worked perfectly, but now SRE765 requires more movement. Also gear stick needed a bit adjusting. Biggest problems were when I noticed some metal glitter on oil. It turned out that I didn´t wash and clean all the parts properly after machining and there were some metal shavings inside engine
Luckily there were no further damages.
Now everything looks very good and therefore I booked dynotime for this Friday! On Saturday I am going to participate on grass roots drifting day
Very exciting times
Postat: mån aug 10, 2020 4:00 pm
av keme
YESSSSSS!!!!
Got it tuned on Friday and went track on Saturday.
https://www.instagram.com/p/CDsya91B5EU/
Had brake issues, steering was a bit funny, a little bit of heat problems, aux belt was slipping of and probably LSD is slipping also. So a bit of repairing, but anyway I got to drive!
Have to fix the problems and go to the track next month!
Postat: mån aug 10, 2020 9:34 pm
av Steve
Are you using the stock accessories and deleted the power steering pump?
I did that on my car and it didnt work as good as the internet said it would. But i bought one of these and never had any more problems:
https://www.ebay.com/itm/LS-Truck-Idler ... SwR8lc-M2p
It relocates the idler pulley so the belt gets a different routing
Postat: tis aug 11, 2020 7:37 am
av keme
Steve skrev:Are you using the stock accessories and deleted the power steering pump?
Yes, I did exactly that and it doesn´t work at all. The aux belt keeps sliping off probably because the route from alternator to crank pulley is too long. I put a gopro shooting at the serpentine belt and that alternator -> crank side moves A LOT.
Thanks for the tip! I have to check out that relocator.
