I have a b21 block which is bored and honed to 92.50 and i put a new mahle -9cc dish casted orig. pistons to it.
Then i have a nice ported 530 head which flows about 200cfm with 46/38 valves, i have a double valve springs and a camshaft which has a duration of 280 degrees at 1mm lift and 12mm max lift, lobe separation angle is 111.
I put a Kl-racing's cast intake manifold to it.
For exhaust i use a tubular one which is a twin-scroll setup.
Turbo is a holset hx40 super, i put boost pressure between 1.6-1.8
My goal is to rev this thing to 7000rpm and a limiter is in 7200rpm.
I use a microsquirt to fuel and spark.
So: what kind of power i can except at 98e or a e85?
Greetings from Finland.
Jussi Alanko.
