fan belt problem
Postat: sön dec 01, 2024 9:57 am
av bmw2101
Re: fan belt problem
Postat: sön dec 01, 2024 10:02 am
av Steve
I don´t know what you did wrong, but is the alternator flexing?
Postat: sön dec 01, 2024 10:15 am
av bmw2101
the alti is on harder bushing, when it had a flat belt on it the bushes went, ill have a look at them tomorrow actually see if they are broken again and that is the problem.
Postat: sön dec 01, 2024 10:36 am
av fulsnut
And the water pump pulley doesn't flex?
Everything lines up?
Postat: fre dec 06, 2024 6:31 pm
av bmw2101
so i have fitted new belts and looked closely. The bottom engine pulley looks the same as the alternator pulley, but the top pulley on the water pump, the belts seem to be 2-3mm closer together. Is there 2 types of pulleys? ive only bought these parts and put them together on this engine, so some could be early parts and some later ones for example.
