Saabel Garage; Chevy C1500 Pickup
Modlendingen
Re: Opel Rekord C -66 "Saabel"
Inlägg av Modlendingen »
Looking forward to it ;)
keme
Inlägg av keme »
A bit low.
Toooo low.
SRyLul
Inlägg av SRyLul »
Correct ridehight: One roll of duct tape?
:thumbright:
Is it a 9k oil pan?
/Samuel R
Projekt: Toyota Corolla KE20 -73 med Saab B234L 199hk
keme
Inlägg av keme »
Correct ride height would be 80mm, because it is the minimum at the registeration inspection :)
Oil pan (also the whole engine) is from Saab 9000.
keme
rear brakes almost done
Inlägg av keme »
Rear brakes assembled. Saab 9000 brake caliber and BMW e36 10x280 rear disc.
Hand brake cable goes directly towards axle, but it is not such a big problem just now.
keme
Inlägg av keme »
Picked up engine wiring harness from TT-Speed. Sweeeet looking wiring harness!!!
keme
Inlägg av keme »
Freddas_ascona
Inlägg av Freddas_ascona »
Is it for the b204 engine? plug and play? I WANT ONE TOO :D
Fredrik Lindgren.. Umeå
Bygger på en Ascona b även kallad Saapel
keme
Inlägg av keme »
Yes, it is custom made plug´n´play harness for b204 engine with Audi COP´s and Tatech engine management. It includes all needed relays and fuses.
keme
Inlägg av keme »
Back on wheels. Still a bit left to do for dyno session which is on this friday. Things are getting intresting...
keme
Inlägg av keme »
blaaaah... Didn´t get it done and couldn´t make it to the dyno. Maybe someday in future...
keme
Inlägg av keme »
New front shocks.
Firgured out also why engine didn´t work on thursday night. Chassis grounding points weren´t good enough, so ECU cound´t work properly. Re-made chassis grounding points and started the engine. Stupid mistake...
Mattias-M
Inlägg av Mattias-M »
this car is awesome
keme
Inlägg av keme »
Fitted those new front shocks today.
keme
Inlägg av keme »
Changed steering wheel. Drivers position is still bad, but now it is almost bearable. Should get that wheel closer to seat and a bit lower it.
