ford som går höga 3 sek repor med singel turbo
Har ni förslag till en bra länk lägg in den här
Bra jobbat! undra va det är för turbo spec på den?
http://www.dragzine.com/news/ziff-hudso ... gle-turbo/
Richard
Re: ford som går höga 3 sek repor med singel turbo
Inlägg av Richard »
http://www.dragzine.com/news/as-the-rad ... ro275-ldr/
With a sleek stance and charcoal gray paint laid on the body, Hudson turned to good friend Kevin Mullins at TKM Performance for the powerplant to stuff between the frame rails and handle all the boost that will be produced by the massive 118 mm single turbocharger.
http://www.dragracingscene.com/features ... 5-radials/
It is a conventional style big-block Chevy that checks in at just over 500ci. A Thomsen Motorsports billet intake sits on top of the engine while a Precision 118mm turbocharger has been fastened to the front of it. A Fuel Tech FT500 stand-alone EFI system controls the Billet Atomizer 700 fuel injectors while an AMS 2000 boost controller tames the massive turbocharger.
så... det kvalar väl in i "äter upp allt som kommer för nära impellern"-ligan ? ;)
Richard Lindahl
"- Mr Flibble is very cross."
http://race.ulkhyvlers.net/
