B20 grinded cam durability?
Miksa89
Inlägg av Miksa89 »
Will grinded cam last without any heat/surface threatment?
Have been using R-cam in my dailydriver with 40DHLA:s with 36 chokes and dynoed 146hp but now aiming to get little more hp. Hoping to get nearly 160hp.
Should R-cam support that hp or should i get little bit more agressive cam?
Have been running that R-cam nearly 4 years and im prepared to change that cam if it shows wear when changing better head.
S-cam may be too agressive for daily driver with stock bottom end.
And now i have been using 6500rpm limiter because heavy stock pistons and thats why i want only little bit more agressive cam compared to R because dont want too narrow power band.
