Saabel Garage; Chevy C1500 Pickup
keme
Re: Saabel Garage; GMC Typhoon #FinnTyphoon
Inlägg av keme »
Few more connectors and a bit of tidying up left on the wiring harness. Starting to look good anyway :)
Nice!
keme
Inlägg av keme »
Original plan was to get this started today. Well, it got delayed, but should get it started soon.
keme
Inlägg av keme »
Quite close to start, but yet a bit away. Maybe the crank trigger is the biggest issue, but I already got the parts for it. I really should get this dynoed in May, so I can drive it a bit before Gatebil trip.
fulsnut
Inlägg av fulsnut »
Any success with the crank trigger?
Gaston
keme
Inlägg av keme »
fulsnut skrev: sön maj 05, 2024 9:32 pm Any success with the crank trigger?
Gaston
I got the parts ready but haven´t yet attached the 36-1 trigger wheel to crank pulley. Bought also a Hall sensor from TT-Speed to read the crank position. Should get this done and then it would be quite much ready for first start.
keme
Inlägg av keme »
Crank shaft trigger in progress
Got the LS coils fitted to valve covers
Checked the fuel pump. Luckily some previous owner had changed a Walbro 255LPH pump to this and it is enough for the current power target. I was prepared to put a Walbro 450 in the tank, but no need for that.
Also replaced original oil pressure sensor with a proper oil pressure measurement which is connected to Maxxecu. Now I can set safety limits for the oilpressure. Had to use one ecu output for the oil pressure gauge :D There is absolutelu no need for it, but I think it is nice that the gauge still works with new ecu 8)
keme
Inlägg av keme »
Got the crank trigger setup done. The bracket come out maybe a bit heavy duty, because I had only 5mm iron at hand. Atleast it is sturdy enough and the sensor should not vibrate :D 36-1 wheel got fitted into crank pulley.
keme
Inlägg av keme »
Well, finaly I got it started!
https://youtube.com/shorts/ms6scuHUuN8
Missed though the Gatebil trip with this but maybe some day I´ll get to do that also. Next step for the Typhoon is to tune it a bit, get it inspected for the road and then take a visit at the dyno :)
keme
Inlägg av keme »
Finally it is moving on its own and it is not leaking anything. Few steps closer to get it in proper driving condition.
keme
Inlägg av keme »
Yes, now it is in full driving condition. Inspected and fully road legal :) Have to drive on the road a bit, get torque converter lockup working, fix possible leakages and then book a dyno time 8)
keme
Inlägg av keme »
First repair after inspection; I was looking engine temps and they were a bit off. Driving low speeds temps were around 90c but at highway they dropped to 73c. I opened the thermostat cover and it was empty. Out a 91c thermostat in it and now it drops to 87 on highway, so all goood. Nice and easy fix for once :D
keme
Inlägg av keme »
Last weekend I drove to Ahvenisto race circuit to watch historic car racing. Had to take picture for proof that I went there with Typhoon :D
keme
Inlägg av keme »
Well, not exactly the start for the winter season as I had in mind.
On the positive side; I drove it in the garage
On the negative side; engine bearings are more or less fucked
On the planning side; next summer it will bigger turbo and working AC. Atleast the bigger turbo.
I am a bit sad I didn´t get to drive this to Gatebil this summer but hopefully some year.
fulsnut
Inlägg av fulsnut »
Maybe it's your luck you didn't drove to Gatebil.
Better next year after a winter with dynotests. :hey:
And it's a very nice car, perfect for a hot summernight.
