Our car is used for drifting and we need more power from the motor and we need some advice on what we can improve because we feel like the car is producing 350 hp max at 1.6 bar so we are thinking that we are doing something wrong
Perhaps the camshaft is the bottleneck and maybe a new camshaft would help this engine
We have a B21A with the following setup:
Running on 98ron.
8.3 compression ratio.
3mm headgasket from klracing.
Homemade twinscroll exhaust manifold(38mm ID and 50cm tubes 1-4 and 2-3).
Plenum intake from KLracing(cheap one).
KG2T camshaft.
Double valve springs.
38 exh and 46 int valves.
H-beam conrods from cxracing.
Stock B21A pistons(the pistons and conrods are equal in weight +-1g).
Head ported lightly.
Garrett TB41 Turbo.
Turbine wheel 73mm ind 63mm exd.
compressor 51mm ind 76mm exd.
Turbine housing is ar 1.15.
M90H gearbox.
3.73 stock volvo rear.
Intercooler(45cmLength 30cmHeight 7cmWidth)
2.5 inch intercooler piping.
3"open exhaust 3 meters in length.
76mm throttlebody.
970cc at 3 bars bosch injectors with extended tip.
Megasquirt 2 using original lower distributor hall sensor setup.
Backpressure measurement at the collector 0.8 bar max at 1.35 bar boost(we have run the engine at 1.6bars but did not measure backpressure then.
Backpressure measurment after turbine 0.1 bar max.
Compression test is 164 at cyl 1, 160 at cyl 2, 155 at cyl 3, 151 at cyl 4
EGT is around 820c at full load and 470c at idle measured at the collector.
Wastegate opens at 4000rpm in 3rd gear.
We have gone up to 7500rpm but the power goes down from 6500.
Here is our ignition map: https://imgur.com/4RQP7bT
Here are some pics https://imgur.com/a/7Cb9oG0
Our youtube channel: https://youtu.be/IY8E5xh4OCA
