injector size
bmw2101
injector size
Inlägg av bmw2101 »
I have a b230 with the E type inlet, it has a 300 deg t5 cam in it, upped the compression, im hoping for 160-190 bhp out of it. I had the volvo t5 injectors in it, but they are damaged. They are expensive here now , what CC of injector should i be looking at. M3 ones are 263CC but im not sure if they are big enough as i the T5 ones were 345CC
thanks
Re: injector size
What kind of efi system are you running
bmw2101
Re: injector size
Inlägg av bmw2101 »
microsquirt, sorry forgot to say. its all programmable
Re: injector size
I would go for something in the 400cc range giving a bit extra headroom.
Also depends on if you are planning to buy new or source it from the junk yard
Re: injector size
fulsnut
Re: injector size
Inlägg av fulsnut »
bmw2101
Re: injector size
Inlägg av bmw2101 »
thats fantastic, ive found some on ebay here in England, £135, i take it these are cone type spray pattern? thanks
Part number: Siemens Deka 9179379.
Please check your own injectors are identical before purchase.
Flow rate: c.360cc/min at 3 bar of pressure.
Resistance: c.15.3 Ohms (high impedance).
New parts fitted: Filters & o-rings.
Quantity: 4 (one set).
Test report: Included (see images for example).
For: Volvo S40 & V40 models using the 1.9/2.0 T4 turbo engine.
fulsnut
Re: injector size
Inlägg av fulsnut »
Strange :roll:
Green 9179379 440cc
Grey 9179379 340cc
Red 9179379 315cc??
Unfortunately i have red :snyft:
fulsnut
Re: injector size
Inlägg av fulsnut »
It's embarrassing, didn't see Steves :doh: :oops:
bmw2101
Re: injector size
Inlägg av bmw2101 »
well thankyou both! ive ordered the grey ones, even though it says 360cc in the ebay advert.
